| Parameter Name | Units | Type | Default | Description |
| CHARGE | double | 0.0 | beam charge (or use CHARGE element) | |
| BROAD_BAND | long | 0 |
broad-band impedance? | |
| RS | double | 0.0 | shunt impedance (Ra=2*Rs) | |
| Q | double | 0.0 | cavity Q | |
| FREQ | double | 0.0 | frequency (BROAD_BAND=1) | |
| INPUTFILE | STRING | NULL | name of file giving impedance (BROAD_BAND=0) | |
| FREQCOLUMN | STRING | NULL | column in INPUTFILE containing frequency | |
| ZXREAL | STRING | NULL | column in INPUTFILE containing real impedance for x plane | |
| ZXIMAG | STRING | NULL | column in INPUTFILE containing imaginary impedance for x plane | |
| ZYREAL | STRING | NULL | column in INPUTFILE containing real impedance for y plane | |
| ZYIMAG | STRING | NULL | column in INPUTFILE containing imaginary impedance for y plane | |
| BIN_SIZE | double | 0.0 | bin size for current histogram (use 0 for autosize) | |
| INTERPOLATE | long | 0 |
interpolate wake? | |
| N_BINS | long | 128 | number of bins for current histogram | |
| SMOOTHING | long | 0 |
smooth current histogram? | |
| SG_ORDER | long | 1 | Savitzky-Golay filter order for smoothing | |
| SG_HALFWIDTH | long | 4 | Savitzky-Golay filter halfwidth for smoothing | |
| DX | double | 0.0 | misalignment | |
| DY | double | 0.0 | misalignment | |
| FACTOR | double | 1 | Factor by which to multiply x and y impedances. |
A simulation of a single-pass broad-band or functionally-specified transverse dipole impedance.
| XFACTOR | double | 1 | Factor by which to multiply x impedance. | |
| YFACTOR | double | 1 | Factor by which to multiply y impedance. | |
| WAKES | STRING | NULL | filename for output of wake | |
| WAKE_INTERVAL | long | 1 | interval in passes at which to output wake |
This element allows simulation of a transverse impedance using a
``broad-band'' resonator or an impedance function specified in a file.
The impedance is defined as the Fourier transform of the wake function
| (32) |
For a resonator impedance, the functional form is
(33) |
When providing an impedance in a file, the user must be careful to conform to these conventions.
Other notes:
