&bunched_beam
STRING bunch = NULL;
long n_particles_per_bunch = 1;
double time_start = 0;
STRING matched_to_cell = NULL;
double emit_x = 0;
double emit_nx = 0;
double beta_x = 1.0;
double alpha_x = 0.0;
double eta_x = 0.0;
double etap_x = 0.0;
double emit_y = 0;
double emit_ny = 0;
double beta_y = 1.0;
double alpha_y = 0.0;
double eta_y = 0.0;
double etap_y = 0.0;
long use_twiss_command_values = 0;
double Po = 0.0;
double sigma_dp = 0.0;
double sigma_s = 0.0;
double dp_s_coupling = 0;
double emit_z = 0;
double beta_z = 0;
double alpha_z = 0;
double momentum_chirp = 0;
long one_random_bunch = 1;
long symmetrize = 0;
long halton_sequence[3] = {0, 0, 0};
long halton_radix[6] = {0, 0, 0, 0, 0, 0};
long randomize_order[3] = {0, 0, 0};
long limit_invariants = 0;
long limit_in_4d = 0;
long enforce_rms_values[3] = {0, 0, 0};
double distribution_cutoff[3] = {2, 2, 2};
STRING distribution_type[3] = {"gaussian","gaussian","gaussian"};
double centroid[6] = {0.0, 0.0, 0.0, 0.0, 0.0, 0.0};
long first_is_fiducial = 0;
long save_initial_coordinates = 1;
&end
bunch -- The (incomplete) name of an SDDS file to which the phase-space coordinates
of the bunches are to be written. Recommended value: ``%s.bun''.
n_particles_per_bunch -- Number of particles in each bunch.
time_start -- The central value of the time coordinate for the bunch.
matched_to_cell -- The name of a beamline from which the Twiss parameters of the bunch
are to be computed.
emit_X -- RMS emittance for the X plane.
emit_nX -- RMS normalized emittance for the X plane. Ignored if emit_X is nonzero.
beta_X, alpha_X, eta_X, etap_X -- Twiss parameters for the X plane.
use_twiss_command_values -- If nonzero, then the values for twiss_output command. It is an error if
no twiss_output command has been given.
Po -- Central momentum of the bunch.
sigma_dp, sigma_s -- Fractional momentum spread, sigma_s is actually the length in dp_s_coupling -- Specifies the coupling between s and emit_z, beta_z, alpha_z -- Provide another way to specify the
longitudinal phase space, either separately from or in combination with
sigma_dp, sigma_s, and dp_s_coupling.
Basically, which values elegant uses depends on what one sets to
nonzero values. If one sets emit_z, then sigma_dp, sigma_s, and
dp_s_coupling are ignored. If one doesn't set emit_z, then elegant uses sigma_dp and sigma_s; it additionally uses alpha_z if
it is nonzero, otherwise it uses dp_s_coupling. For reference, the
relationship between them is
. Note that to impart a chirp that
results in compression for
(e.g., a normal four-dipole
chicane), one must have
or
momentum_chirp -- Permits imparting an additional
momentum chirp to the beam, in units of 1/m. E.g., a value of 1
indicates that a 1mm long bunch has a linear variation in momentum of
0.1% from end-to-end. A positive chirp is needed to provide
compression of a bunch with an ordinary
one_random_bunch -- If non-zero, then only one random
particle distribution is generated. Otherwise, a new distribution
will be generated for every simulation step.
enforce_rms_values[3] -- Flags, one for each plane,
indicating whether to force the distribution to have the specified RMS
properties.
distribution_cutoff[3] -- Distribution cutoff parameters
for each plane. For gaussian distributions, this is the number of
sigmas to use. For other distributions (except dynamic aperture),
this number simply multiplies the sizes. This is potentially
confusing and hence it is suggested that the distribution cutoff be
set to 1 for nongaussian beams.
The exception is ``dynamic-aperture'' distribution type. In this case, the cutoff value is the number of grid points in the dimension in question.
distribution_type[3] -- Distribution type for each
plane. May be ``gaussian'', ``hard-edge'', ``uniform-ellipse'',
``shell'', ``dynamic-aperture'', ``line'', ``halo(gaussian)''.
For the transverse plane, the interpretation of the emittance is
different for the different beam types. For gaussian beams, the
emittances are rms values. For all other types,
times the distribution cutoff defines the edge of the beam in position
space, while
cutoff defines the edge of the beam in slope space.
A hard-edge beam is a uniformly-filled parallelogram in phase space. A uniform-ellipse beam is a uniformly-filled ellipse in phase space. A shell beam is a hollow ellipse in phase space. A dynamic aperture beam has zero slope and uniform spacing in position coordinates. A line beam is a line in phase space. A ``halo(gaussian)'' beam is the part of the gaussian distribution beyond the distribution cutoff.
limit_invariants -- If non-zero, the distribution
cutoffs are applied to the invariants, rather than to the coordinates.
This is useful for gaussian beams when the distribution cutoff is
small.
limit_in_4d -- If non-zero, then the transverse
distribution is taken to be a 4-d gaussian or uniform distribution.
One of these must be chosen using the distribution_type
control. It must be the same for x and y. This is useful, for
example, if you want to make a cylindrically symmetric beam.
symmetrize -- If non-zero, the distribution is symmetric
under changes of sign in the coordinates. Automatically results in a
zero centroid for all coordinates.
halton_sequence[3] and halton_radix[6] -- This
provides a ``quiet-start'' feature by choosing Halton sequences in
place of random number generation. There are three new variables that
control this feature. halton_sequence is an array of three
flags that permit turning on Halton sequence generation for the
horizontal, vertical, or longitudinal planes. For example,
halton_sequence[0] = 3*1 will turn on Halton sequences for all
three planes, while halton_sequence[2] = 1, will turn it on for
the longitudinal plane only.
halton_radix is an array of six integers that permit giving the
radix for each sequence (i.e., x, x', y, y', t, p). Each radix must
be a prime number. One should never use the same prime for two
sequences, unless one randomizes the order of the sequences relative to
each other (see the next item). If these are left at zero, then
elegant chooses values that eliminate phase-space banding to some
extent. The user is cautioned to plot all coordinate combinations for
the initial phase space to ensure that no unacceptable banding is
present.
A suggested way to use Halton sequences is to set
halton_radix[0] = 2, 3, 2, 3, 2, 3 and
to set
randomize_order[0] = 2, 2, 2,. This avoids banding that may
result from choosing larger radix values.
randomize_order[3] -- Allows randomizing the order of
assigned coordinates for the pairs (x, x'), (y, y'), and (t,p). 0
means no randomization; 1 means randomize (x, x', y, y', t, p) values
independently, which destroys any x-x', y-y', and t-p correlations; 2
means randomize (x, x'), (y, y'), and (t, p) in pair-wise fashion.
This is used with Halton sequences to remove banding. It is suggested
that that the user employ sddsanalyzebeam to verify that the
beam properties when randomization is used.
centroid[6] -- Centroid offsets for each of the six coordinates.
first_is_fiducial -- Specifies that the first beam
generated shall be a single particle beam, which is suitable for
fiducialization. See the section on ``Fiducialization in
elegant'' for more discussion.
save_initial_coordinates -- A flag that, if set, results
in saving initial coordinates of tracked particles in memory. This is
the default behavior. If unset, the initial coordinates are not
saved, but are regenerated each time they are needed. This is more
memory efficient and is useful for tracking very large numbers of
particles.
