&optimization_term
STRING term = NULL;
double weight = 1.0;
&end
term -- An rpn expression giving one term to be optimized.
If more than one optimization_term command is given, then the terms are
added. The advantage of using this command over giving an equation via
optimization_setup is that elegant will report the value of
each term as it performs the optimization (if a log_file is given to
optimization_setup). This permits determination of
which terms are causing problems for the optimization.
Please see the entry for equation under optimization_setup for details on designing optimization terms.
weight -- The weight to assign to this term. If zero, the term
is ignored.
