next up previous
Next: HKICK Up: Element Dictionary Previous: FTRFMODE
HISTOGRAM
Request for histograms of particle coordinates to be output to SDDS file.
Parameter Name Units Type Default Description
FILENAME   STRING   filename for histogram output
INTERVAL   long 1 interval in passes between output
START_PASS   long 0 starting pass for output
BINS   long 50 number of bins
FIXED_BIN_SIZE   long 0 if nonzero, bin size is fixed after the first histogram is made
X_DATA   long 1 histogram x and x'?
Y_DATA   long 1 histogram y and y'?
LONGIT_DATA   long 1 histogram t and p?
BIN_SIZE_FACTOR   double 1 multiply computed bin size by this factor before histogramming
NORMALIZE   long 1 normalize histogram with bin size and number of particles?
DISABLE   long 0 If nonzero, no output will be generated.
next up previous
Robert Soliday 2005-09-01
