Next: MATR
Up: Element Dictionary
Previous: MAPSOLENOID
A marker, equivalent to a zero-length drift space.
| Parameter Name |
Units |
Type |
Default |
Description |
| FITPOINT |
long |
0 |
supply Twiss parameters, moments, floor coordinates for optimization? |
If FITPOINT=0, this element results only in generation of additional output rows in the various
files that contain output vs s. For example, Twiss parameters, closed orbits, and matrices vs s will
all contain a row for each occurrence of each marker element.
If FITPOINT=1, the element has additional functionality in the context of optimizations. In particular,
for occurrence N of the defined element Element, a series of symbols are created of the
form Element#N.quantity, where quantity has the following values:
- The quantity pCentral will be created, giving the reference value of
at the marker location.
- The quantities Cx, Cxp, Cy, Cyp, Cs, and Cdelta will be created,
giving coordinate centroid values from tracking to the marker location.
- The quantity Particles will be created, giving the number of particles tracked to the marker location.
- The quantities sij will be created, giving
at the marker location, where
and
- The quantities Rij will be created, for
and
giving the accumulated first-order transport matrix to the marker location.
- If the default matrix order (as set in run_setup) is 2 or greater, the quantities Tijk
, and
giving the accumulated second-order transport matrix to the marker location.
- If Twiss parameter calculations are being performed (via twiss_output), then the quantities
alphax, betax, nux, etax, etapx, and etaxp, along with similarly-named
quantities for the vertical plane, will be created, giving twiss parameter values at the marker location.
Note that etapx and etaxp are the same, being alternate names for
- If closed orbit calculations are being performed (via correct or closed_orbit), then
the quantities xco, yco, xpco, and ypco will be created, giving the
x and y closed orbits and their slopes, respectively, at the marker location.
- If floor coordinate calculations are begin performed (via floor_coordinates), then the quantities
X, Y, Z, theta, phi, psi, and s will be created. These are,
respectively, the three position coordinates, the three angle coordinates, and the total arc length
Next: MATR
Robert Soliday
2006-05-05
