| Parameter Name | Units | Type | Default | Description |
| JX | double | 1 | x damping partition number | |
| JY | double | 1 | y damping partition number | |
| JDELTA | double | 2 | momentum damping partition number | |
| EXREF | double | 0.0 | reference equilibrium x emittance | |
| EYREF | double | 0.0 | reference equilibrium y emittance | |
| SDELTAREF | double | 0.0 | reference equilibrium fractional momentum spread | |
| DDELTAREF | double | 0.0 | reference fractional momentum loss (per turn) | |
| PREF | double | 0.0 | reference momentum (to which other reference values pertain) | |
| COUPLING | double | 0.0 | x-y coupling | |
| FRACTION | double | 1 | fraction of implied SR effect to simulate with each instance | |
| DAMPING | long | 1 | include damping, less rf effects? | |
| QEXCITATION | long | 1 | include quantum excitation? | |
| LOSSES | long | 1 | include average losses? | |
| CUTOFF | double | 100 | cutoff (in sigmas) for gaussian random numbers |
This element allows simulation of synchrotron radiation effects in a
lumped fashion for quick, approximate results.  There are two ways to
set up the element: explicit initialization or automatic
initialization.
In explicit initialization, the user supplies the quantities EXREF, EYREF, SDELTAREF, DDELTAPREF, and PREF. These are, respectively, the reference values for the x-plane emittance, y-plane emittance, fractional momentum spread, energy loss per turn, and momentum. The first four values pertain to the reference momentum. JX, JY, and JDELTA may also be given, although the defaults work for typical lattices.
In automatic initialization, the user turns on the radiation integral feature in twiss_output, causing elegant to automatically compute the above quantities. The COUPLING parameter can be used to change the partitioning of quantum excitation between the horizontal and vertical planes.
