| Parameter Name | Units | Type | Default | Description |
| L | double | 0.0 | length | |
| K1 | double | 0.0 | geometric strength | |
| TILT | double | 0.0 | rotation about longitudinal axis | |
| BORE | double | 0.0 | bore radius | |
| B | double | 0.0 | pole tip field (used if bore nonzero) | |
| DX | double | 0.0 | misalignment | |
| DY | double | 0.0 | misalignment | |
| DZ | double | 0.0 | misalignment | |
| FSE | double | 0.0 | fractional strength error | |
| HKICK | double | 0.0 | horizontal correction kick | |
| VKICK | double | 0.0 | vertical correction kick | |
| HCALIBRATION | double | 1 | calibration factor for horizontal correction kick | |
| VCALIBRATION | double | 1 | calibration factor for vertical correction kick | |
| HSTEERING | long | 0 |
use for horizontal correction? | |
| VSTEERING | long | 0 |
use for vertical correction? | |
| N_KICKS | long | 4 | number of kicks | |
| SYNCH_RAD | long | 0 |
include classical synchrotron radiation? | |
| SYSTEMATIC_MULTIPOLES | STRING | NULL | input file for systematic multipoles | |
| RANDOM_MULTIPOLES | STRING | NULL | input file for random multipoles | |
| STEERING_MULTIPOLES | STRING | NULL | input file for multipole content of steering kicks | |
| INTEGRATION_ORDER | long | 4 | integration order (2 or 4) | |
| SQRT_ORDER | long | 0 |
Order of expansion of square-root in Hamiltonian. 0 means no expansion. | |
| ISR | long | 0 |
include incoherent synchrotron radiation (scattering)? |
This element simulates a quadrupole using a kick method based on
symplectic integration. The user specifies the number of kicks and
the order of the integration. For computation of twiss parameters and
response matrices, this element is treated like a standard thick-lens
quadrupole; i.e., the number of kicks and the integration order become
irrelevant.
SYSTEMATIC_MULTIPOLES and
RANDOM_MULTIPOLES
fields. These fields give the names of SDDS files that supply the
multipole data. The files are expected to contain a single page of
data with the following elements:
Specification of systematic higher multipoles due to steering fields is
supported through the STEERING_MULTIPOLES field. This field gives the
name of an SDDS file that supplies the multipole data. The file is
expected to contain a single page of data with the following elements:
The dominant systematic multipole term in the steering field is a sextupole. Note that elegant presently does not include such sextupole contributions in the computation of the chromaticity via the twiss_output command. However, these chromatic effects will be seen in tracking.
Apertures specified via an upstream MAXAMP element or an aperture_input
command will be imposed inside this element, with the following rules/limitations:
ELLIPTICAL qualifier
is set for MAXAMP.
