next up previous
Next: MODRF Up: Element Dictionary Previous: MATTER
MAXAMP
A collimating element that sets the maximum transmitted particle amplitudes for all following elements, until the next MAXAMP.
Parameter Name Units Type Default Description
X_MAX $M$ double 0.0 x half-aperture
Y_MAX $M$ double 0.0 y half-aperture
ELLIPTICAL   long 0 is aperture elliptical?
EXPONENT   long 2 exponent for boundary equation in elliptical mode. 2 is a true ellipse.
OPEN_SIDE   STRING NULL which side, if any, is open (+x, -x, +y, -y)
This element sets the aperture for itself and all subsequent elements. The settings are in force until another MAXAMP element is seen.
This can introduce unexpected behavior when beamlines are reflected. For example, consider the beamline
L1:  LINE=( ... )
L2:  LINE=( ... )
MA1: MAXAMP,X_MAX=0.01,Y_MAX=0.005
MA2: MAXAMP,X_MAX=0.01,Y_MAX=0.002
BL1: LINE=(MA1,L1,MA2,L2)
BL:  LINE=(BL1,-BL1)
This is equivalent to
BL:  LINE=(MA1,L1,MA2,L2,-L2,MA2,-L1,MA1)
Note that the aperture MA1 is the aperture for all of the first instance of beamline L1, but that MA2 is the aperture for the second instance, -L1. This is probably not what was intended. To prevent this, it is recommended to always use MAXAMP elements in pairs:
BL1: LINE=(MA2,MA1,L1,MA1,MA2,L2)
BL:  LINE=(BL1,-BL1)
which is equivalent to
BL:  LINE=(MA2,MA1,L1,MA1,MA2,L2,-L2,MA2,MA1,-L1,MA1,MA2)
Now, both instances of L1 have the aperture defined by MA1 and both instances of L2 have the aperture defined by MA2.
next up previous
Robert Soliday 2006-09-05
