| Parameter Name | Units | Type | Default | Description |
| CHARGE | double | 0.0 | beam charge (or use CHARGE element) | |
| BROAD_BAND | long | 0 |
broad-band impedance? | |
| RA | double | 0.0 | shunt impedance | |
| RS | double | 0.0 | shunt impedance (Ra=2*Rs) | |
| Q | double | 0.0 | cavity Q | |
| FREQ | double | 0.0 | frequency (BROAD_BAND=1) | |
| ZREAL | STRING | NULL | ||
| ZIMAG | STRING | NULL | ||
| BIN_SIZE | double | 0.0 | bin size for current histogram (use 0 for autosize) | |
| N_BINS | long | 128 | number of bins for current histogram | |
| WAKES | STRING | NULL | filename for output of wake | |
| WAKE_INTERVAL | long | 1 | interval in passes at which to output wake | |
| AREA_WEIGHT | long | 0 |
use area-weighting in assigning charge to histogram? | |
| INTERPOLATE | long | 0 |
interpolate wake? | |
| SMOOTHING | long | 0 |
smooth current histogram? | |
| SG_ORDER | long | 1 | Savitzky-Golay filter order for smoothing | |
| SG_HALFWIDTH | long | 4 | Savitzky-Golay filter halfwidth for smoothing | |
| REVERSE_TIME_ORDER | long | 0 |
Reverse time-order of particles for wake computation? | |
| FACTOR | double | 1 | Factor by which to multiply impedance. | |
| START_ON_PASS | long | 0 |
The pass on which the impedance effects start. |
A simulation of a single-pass broad-band or functionally specified longitudinal
impedance.
| RAMP_PASSES | long | 0 |
Number of passes over which to linearly ramp up the impedance to full strength. | |
| HIGH_FREQUENCY_CUTOFF0 | double | -1 | Frequency at which smoothing filter begins. If not positive, no frequency filter smoothing is done. Frequency is in units of Nyquist (0.5/binsize). | |
| HIGH_FREQUENCY_CUTOFF1 | double | -1 | Frequency at which smoothing filter is 0. If not given, defaults to HIGH_FREQUENCY_CUTOFF0. |
This element allows simulation of a longitudinal impedance using a
``broad-band'' resonator or an impedance function specified in a file.
The impedance is defined as the Fourier transform of the wake function
| (32) |
For a resonator impedance, the functional form is
(33) |
When providing an impedance in a file, the user must be careful to conform to these conventions.
Other notes:
