next up previous
Next: ECOL Up: Element Dictionary Previous: DRIF
DSCATTER
A scattering element to add random changes to particle coordinates according to a user-supplied distribution function
Parameter Name Units Type Default Description
PLANE   STRING NULL Plane to scatter: xp, yp, dp (dp is deltaP/P)
FILENAME   STRING NULL Name of SDDS file containing distribution function.
VALUENAME   STRING NULL Name of column containing the independent variable for the distribution function data.
CDFNAME   STRING NULL Name of column containing the cumulative distribution function data.
PDFNAME   STRING NULL Name of column containing the probability distribution function data.
ONCEPERPARTICLE   long 0 If nonzero, each particle can only get scattered once by this element.
FACTOR   double 1 Factor by which to multiply the independent variable values.
PROBABILITY   double 1 Probability that any particle will be selected for scattering.
GROUPID   long -1 Group ID number (nonnegative integer) for linking once-per-particle behavior of multiple elements.
RANDOMSIGN   long 0 If non-zero, then the scatter is given a random sign. Useful if distribution data is one-sided.
LIMITPERPASS   long -1 Maximum number of particles that will be scattered on each pass.
LIMITTOTAL   long -1 Maximum number of particles that will be scatter for each step.
STARTONPASS   long 0 Pass number to start on.
ENDONPASS   long -1 Pass number to end on (inclusive). Ignored if negative.
next up previous
Robert Soliday 2006-09-05
