next up previous
Next: ILMATRIX Up: Element Dictionary Previous: HMON
IBSCATTER
A simulation of intra-beam scattering.
Parameter Name Units Type Default Description
COUPLING   double 1 x-y coupling
FACTOR   double 1 factor by which to multiply growth rates before using
CHARGE $C$ double 0.0 beam charge (or use CHARGE element)
DO_X   long 1 do x-plane scattering?
DO_Y   long 1 do y-plane scattering?
DO_Z   long 1 do z-plane scattering?
SMOOTH   long 0 Use smooth method instead of random numbers?
VERBOSITY   long 0 Set verbosity level
FORCE_MATCHED_TWISS   long 0 Force computations to be done with twiss parameters of the beamline, not the beam.
Robert Soliday 2006-09-05
