Next: LTHINLENS
Up: Element Dictionary
Previous: LSCDRIFT
A non-symplectic numerically integrated planar undulator including optional co-propagating laser beam for laser modulation of the electron beam.
Parallel capable? : no
| Parameter Name |
Units |
Type |
Default |
Description |
| L |
double |
0.0 |
length |
| BU |
double |
0.0 |
Undulator peak field |
| PERIODS |
long |
0 |
Number of undulator periods. |
| METHOD |
STRING |
non-adaptive runge-kutta |
integration method (runge-kutta, bulirsch-stoer, modified-midpoint, two-pass modified-midpoint, leap-frog, non-adaptive runge-kutta) |
| FIELD_EXPANSION |
STRING |
ideal |
ideal, exact, or "leading terms" |
| ACCURACY |
double |
0.0 |
Integration accuracy for adaptive integration. (Not recommended) |
| N_STEPS |
long |
0 |
Number of integration steps for non-adaptive integration. |
| POLE_FACTOR1 |
double |
0.155717533964439 |
Strength factor for the first and last pole. |
| POLE_FACTOR2 |
double |
0.380687615192693 |
Strength factor for the second and second-to-last pole. |
| POLE_FACTOR3 |
double |
0.80282999969846 |
Strength factor for the third and third-to-last pole. |
| LASER_WAVELENGTH |
double |
0.0 |
Laser wavelength. If zero, the wavelength is calculated from the resonance condition. |
| LASER_PEAK_POWER |
double |
0.0 |
laser peak power |
| LASER_W0 |
double |
1 |
laser spot size at waist |
| LASER_PHASE |
double |
0.0 |
laser phase |
This element simulates a planar undulator, together with an optional
co-propagating laser beam that can be used as a beam heater or
modulator. The simulation is done by numerical integration of the
Lorentz equation. It is not symplectic, and hence this element is not
recommended for long-term tracking simulation of undulators in storage
rings.
The fields in the undulator can be expressed in one of three ways.
The FIELD_EXPANSION parameter is used to control which method is used.
- The exact field, given by (see section 3.1.5 of the Handbook of
Accelerator Physics and Engineering)
(4) |
(5) |
and
(6) |
where
and
is the undulator period.
This is the most precise method, but also the slowest.
- The field expanded to leading order in
(7) |
and
(8) |
In most cases, this gives results that are very close to the exact fields,
at a savings of 10% in computation time.
- The ``ideal'' field:
(9) |
(10) |
This is about 10% faster than the leading-order mode, but less
precise. Small differences from results with the exact field may be
seen. Generally, these are too small to be a concern. As a result,
this is the default mode.
By default, if the laser wavelength is not given, it is computed from the resonance
condition:
(11) |
where
is the relativistic factor for the beam and
is the
undulator parameter.
The adaptive integrator doesn't work well for this element, probably
due to sudden changes in field derivatives in the first and last three
poles (a result of the implementation of the undulator terminations).
Hence, the default integrator is non-adaptive Runge-Kutta. The
integration accuracy is controlled via the N_STEPS parameter.
N_STEPS should be about 100 times the number of undulator periods.
The expressions for the laser field used by this element were provided
by P. Emma (SLAC).
Next: LTHINLENS
Previous: LSCDRIFT
Robert Soliday
2007-04-02
