next up previous
Next: MONI Up: Element Dictionary Previous: MAXAMP
MODRF
A first-order matrix RF cavity with exact phase dependence, plus optional amplitude and phase modulation.
Parallel capable? : yes
Parameter Name Units Type Default Description
L $M$ double 0.0 length
VOLT $V$ double 0.0 nominal voltage
PHASE $DEG$ double 0.0 nominal phase
FREQ $Hz$ double 500000000 nominal frequency
Q   double 0.0 cavity Q
PHASE_REFERENCE   long 0 phase reference number (to link with other time-dependent elements)
AMMAG   double 0.0 magnitude of amplitude modulation
AMPHASE $DEG$ double 0.0 phase of amplitude modulation
AMFREQ $Hz$ double 0.0 frequency of amplitude modulation
AMDECAY $1/s$ double 0.0 exponetial decay rate of amplitude modulation
PMMAG $DEG$ double 0.0 magnitude of phase modulation
PMPHASE $DEG$ double 0.0 phase of phase modulation
PMFREQ $Hz$ double 0.0 frequency of phase modulation
PMDECAY $1/s$ double 0.0 exponetial decay rate of phase modulation
FIDUCIAL   STRING NULL mode for determining fiducial arrival time (light, tmean, first, pmaximum)
next up previous
Robert Soliday 2007-04-02
