next up previous
Next: QUFRINGE Up: Element Dictionary Previous: PFILTER
QUAD
A quadrupole implemented as a matrix, up to 3rd order.
Parallel capable? : yes
Parameter Name Units Type Default Description
L $M$ double 0.0 length
K1 $1/M^{2}$ double 0.0 geometric strength
TILT $RAD$ double 0.0 rotation about longitudinal axis
FFRINGE   double 0.0 fraction of length occupied by linear fringe region
DX $M$ double 0.0 misalignment
DY $M$ double 0.0 misalignment
DZ $M$ double 0.0 misalignment
FSE $M$ double 0.0 fractional strength error
HKICK $RAD$ double 0.0 horizontal correction kick
VKICK $RAD$ double 0.0 vertical correction kick
HCALIBRATION   double 1 calibration factor for horizontal correction kick
VCALIBRATION   double 1 calibration factor for vertical correction kick
HSTEERING   long 0 use for horizontal steering?
VSTEERING   long 0 use for vertical steering?
ORDER   long 0 matrix order
FRINGE_TYPE   STRING inset type of fringe: "inset" or "fixed-strength"
This element simulates a quadrupole using a matrix of first, second, or third order.
By default, the element has hard edges and constant field within the defined length, L. However, soft-edge effects (up to second order) may be added using the FFRINGE and FRINGE_TYPE parameters. If FFRINGE is zero (the default), then the magnet is hard-edged. If FFRINGE is positive, then the magnet has linear fringe fields of length FFRINGE*L/2 at each end. That is, the total length of fringe field from both ends combined is FFRINGE*L.
Depending on the value of FRINGE_TYPE, the fringe fields are modeled as contained within the length L (``inset'' type) or extending symmetrically outside the length L (``fixed-strength'' type).
For ``inset'' type fringe fields, the length of the ``hard core'' part of the quadrupole is L*(1-FFRINGE). For ``fixed-strength'' type fringe fields, the length of the hard core is L*(1-FFRINGE/2). In the latter case, the fringe gradient reaches 50% of the hard core value at the nominal boundaries of the magnet. This means that the integrated strength of the magnet does not change as the FFRINGE parameter is varied. This is not the case with ``inset'' type fringe fields.
next up previous
Robert Soliday 2007-04-02
