Parameter Name | Units | Type | Default | Description |
RA | ![]() |
double | 0.0 | shunt impedance |
RS | ![]() |
double | 0.0 | shunt impedance (Ra=2*Rs) |
Q | double | 0.0 | cavity Q | |
FREQ | ![]() |
double | 0.0 | frequency |
CHARGE | ![]() |
double | 0.0 | beam charge (or use CHARGE element) |
BETA | double | 0.0 | normalized load impedance | |
BIN_SIZE | ![]() |
double | 0.0 | bin size for current histogram (use 0 for autosize) |
N_BINS | long | 20 | number of bins for current histogram | |
PLANE | STRING | both | x, y, or both | |
SAMPLE_INTERVAL | long | 1 | passes between output to RECORD file | |
PER_PARTICLE_OUTPUT | long | 0 |
If non-zero, then in BINLESS mode, provides per-particle output of RECORD data. | |
RECORD | STRING | NULL | output file for cavity data | |
SINGLE_PASS | long | 0 |
if nonzero, don't accumulate field from pass to pass | |
RIGID_UNTIL_PASS | long | 0 |
don't affect the beam until this pass | |
DX | ![]() |
double | 0.0 | misalignment |
DY | ![]() |
XFACTOR | double | 1 | factor by which to multiply shunt impedances | |
YFACTOR | double | 1 | factor by which to multiply shunt impedances | |
RAMP_PASSES | long | 0 |
Number of passes over which to linearly ramp up the impedance to full strength. | |
BINLESS | long | 0 |
If nonzero, use algorithm that doesn't requiring binning. Best for few particles, widely spaced. |
