next up previous
Next: WAKE Up: Element Dictionary Previous: VKICK
VMON
A vertical position monitor, accepting a rpn equation for the readout as a function of the actual position (y).
Parallel capable? : yes
Parameter Name Units Type Default Description
L $M$ double 0.0 length
DX $M$ double 0.0 misalignment
DY $M$ double 0.0 misalignment
WEIGHT   double 1 weight in correction
TILT   double 0.0 rotation about longitudinal axis
CALIBRATION   double 1 calibration factor for readout
ORDER   long 0 matrix order
READOUT   STRING NULL rpn expression for readout (actual position supplied in variable y)
CO_FITPOINT   long 0 If nonzero, then closed orbit value is placed in variable $<$name$>$#$<$occurence$>$.yco
next up previous
Robert Soliday 2007-04-02
