&optimization_setup
STRING equation = NULL;
STRING mode = "minimize";
STRING method = "simplex";
double tolerance = -0.01;
double target = 0;
long soft_failure = 1;
long n_passes = 2;
long n_evaluations = 500;
long n_restarts = 0;
long matrix_order = 1;
STRING log_file = NULL;
long output_sparsing_factor = 0;
long balance_terms = 0;
double restart_worst_term_factor = 1;
long restart_worst_terms = 1;
long verbose = 1;
double simplex_divisor = 3;
double simplex_pass_range_factor = 1;
long include_simplex_1d_scans = 1;
long start_from_simplex_vertex1 = 0;
long restart_random_numbers = 0;
&end
equation -- An rpn equation for the optimization
function, expressed in terms of any parameters of any optimization
variables and the ``final'' parameters of the beam (as recorded in the
final output file available in the run_setup namelist).
The optimization variables or covariables may appear in the equation
in the form <element-name>.<parameter-name>, all in capital
letters. In addition, initial values of variables and covariables
are available in the form <element-name>.<parameter-name>0.
Data from MARK elements with FITPOINT=1 may be used via
symbols of the form
<element-name>#<occurrence-number>.<parameter-name>, where
<parameter-name> can be a Twiss parameter name (if the twiss
command was given), a floor coordinate name (if the floor command was
given, a beam-size or centroid name, a sigma-matrix element, or a
closed orbit value (xco, xpco, etc) if closed orbit
calculations are requested. The parameter names are the same as those
used in the corresponding output files. Beam sizes, centroids, and
sigma-matrix elements are from tracking the particle distribution.
See the documentation for the MARK element for a more detailed listing.
If closed orbit calculations are requested, data from MONI, HMON, and VMON elements that have CO_FITPOINT=1 is
available under the names bpmName#occurence.qco, where q is x, xp, y, or yp.
If response matrix calculation is requested, response matrix values
are available in variables with names PlaneR_bpmName#occurence_corrName#occurence.corrParam, where Plane is H (horizontal) or V (vertical) and corrParam is the parameter of the corrector
used for changing the orbit (e.g., HKICK or VKICK for a
KICKER element).
If the twiss command was given, one may also refer to statistics of
Twiss parameters in the form <statistic>.<parameter-name>,
where <statistic> is either min or max. One may
also use the symbols nux, dnux/dp, (and corresponding
symbols for y), alphac, and alphac2. These are the
tune, chromaticity, and first- and second- order momentum compaction
factors. The final values of the Twiss parameters are referred to
simply as betax, etax, etc.
If the twiss command was given and radiation integral computation
was requested, one may use ex0 and Sdelta0 for
the equilibrium emittance and momentum spread, plus J<plane>
and tau<plane> for the damping partition and damping time,
where <plane> is x, y, or delta.
The coupling integral and emittance ratio due to x-y coupling may
be accessed using the symbols couplingIntegral and
emittanceRatio. See section 3.1.4.4 of [18].
If the floor_coordinates command was given, one may use
X, Z, and theta to refer to the final values of
the floor coordinates.
If the sasefel command was given, one may use variables of
the form SASE.<property>, where <property> is one
of gainLength, saturationLength,
saturationPower, or lightWavelength.
Finally, one may use any of the names from the ``final'' output file
(see run_setup), e.g., Sx (x beamsize) or eny (y
normalized emittance). These refer to tracked properties of the beam.
The equation may be left blank, in which case the user must give one
or more optimization_term commands. These use the same
symbols, of course.
There are several rpn functions that are useful in constructing a good optimization equation. These are ``soft-edge'' greater-than, less-than, and not-equal functions, which have the names segt, selt, and sene, respectively. The usage is as follows:
max.betax 10 .1 segt.
betax 3 .1 selt.
mode -- May be either ``minimize'' or ``maximize''.
method -- May be one of ``simplex'', ``grid'', ``powell'', ``randomwalk'', ``randomsample'', or ``sample''. Recommended methods are ``simplex'' and ``randomwalk''. The latter is very useful when the lattice is unstable or nearly so.
tolerance -- The convergence criterion for the optimization, with a negative value indicating
a fractional criterion.
target -- The value which, if reached, results in immediate termination of the optimization,
whether it has converged or not.
soft_failure -- A flag indicating, if set, that failure of an optimization pass should not
result in termination of the optimization.
n_evaluations -- The number of allowed evaluations of
the optimization function. If simplex optimization is used, this is
the number of allowed evaluations per pass.
n_passes -- The number of optimization passes made to
achieve convergence (``simplex'' only). A pass ends (roughly) when
the number of evaluations is completed or the function doesn't change
within the tolerance. A new pass involves starting the optimization
again using step sizes determined from the range of the simplex and
the factor simplex_pass_factor.
n_restarts -- The number of complete restarts of the
optimization (simplex only). This is an additional loop around the
n_passes loop. The difference is that a restart involves using
the optimized result but the original step sizes. It is highly
recommended that this feature be used if convergence problems are seen.
restart_worst_term_factor, restart_worst_terms -- Often
when there are convergence problems, it is because a few terms are causing
difficulty. Convergence can often be obtained by increasing the weighting
of these terms. If restart_worst_term_factor is positive, then elegant
will multiply the weight of the restart_worst_terms largest terms by this
factor at the beginning of a restart.
matrix_order -- Specifies the highest order of matrix elements that
should be available for fitting. Elements up to third order are available for
the terminal point of the beamline, and up to secod order for interior fit points.
Names for first-, second-, and third-order elements are of the form
Rij, Tijk, and Uijkl.
log_file -- A file to which progress reports will be written as optimization proceeds.
For SDDS data, use the final output file from the run_setup namelist.
output_sparsing_factor -- If set to a value larger than 0, results in
sparsing of output to the ``final'' file (see run_setup). This can make
a significant difference in the optimization speed.
balance_terms -- If nonzero, then all terms of the optimization expression have
their weights adjusted so they make equal contributions to the penalty function. This can
help prevent optimization of a single term at the expense of others. It is performed only
for the initial value of the optimization function.
simplex_divisor -- The factor by which simplex step sizes are changed as the
optimization algorithm searches for a valid initial simplex.
simplex_pass_range_factor -- When starting a new pass, the simplex optimizer takes
the range over the previous simplex of each variable times this factor
as the starting step size for that variable. This can be useful if the optimization brings
the system close to an instability. In such a case, the simplex routine may have trouble
constructing an initial simplex if the range of the variables is large. Setting this control
to a value less than 1 may help.
include_simplex_1d_scans -- If nonzero, optimizer performs single-variable scans prior to
starting simplex optimization. This is usually a good idea, but in some cases it will cause problems.
For example, if your design is on the edge of being unstable, you may get some many errors from the
initial steps that the single-variable optimizer can't continue. Disabling the
single-variable scans will sometimes solve this.
start_from_simplex_vertex1 -- If nonzero, optimizer uses the initial simplex vertex as the
starting point for each new 1d scan. Otherwise, it uses the result of the previous scan.
restart_random_numbers -- If nonzero, the random number generators used by elegant are
reset for each evaluation of the optimization function. This is valuable if one is optimizing tracking
results that involve random processes (e.g., ISR or scattering).
