next up previous
Next: run_control Up: Namelist Command Dictionary Previous: rpn_expression
rpn_load
&rpn_load
    STRING tag = NULL;
    STRING filename = NULL;
    STRING match_column = NULL;
    STRING match_column_value = NULL;
    long matching_row_number = -1;
    STRING match_parameter = NULL;
    STRING match_parameter_value = NULL;
    long use_row = -1;
    long use_page = -1;
&end
This command is used to facilitate multi-stage optimization runs by allowing convenient loading of data from SDDS files into RPN variables. For example, one may match the final Twiss parameters of a lattice to the parameters stored in an SDDS file from a different run.
next up previous
Robert Soliday 2007-04-02
