Next: twiss_analysis
Up: Namelist Command Dictionary
Previous: steering_element
- type: setup command.
- function: Changes the type of selected elements, which may be used to
turn off unneeded diagnostics and speed up tracking when concatenation
is being used.
- notes:
- Any number of these commands may be given.
- Not effective unless given prior to
run_setup.
- The only property of the original element that is preserved is
the length. For example, transmuting a SBEN into a CSBEN will not
have the expected result.
&transmute_elements
STRING name = NULL,
STRING type = NULL,
STRING exclude = NULL,
STRING new_type = "DRIF",
long disable = 0;
long clear = 0;
&end
name -- Possibily wild-card containing string specifying the
elements to which the transmutation specification is to be applied.
type -- Possibily wild-card containing string specifying the
element types to which the transmutation specification is to be applied.
exclude -- Possibily wild-card containing string specifying
elements to be excluded from the specified transmutation. Does not
affect elements transmuted due to other specifications.
new_type -- Type into which specified elements will be transmuted.
disable -- If nonzero, the command is ignored.
clear -- If nonzero, all prior transmutation specifications are deleted.
Robert Soliday
2007-04-02
