Next: Changes and Additions to
Up: Highlights of What's New
Previous: New and Modified Elements
- The rpn_load command was added, which helps in multi-stage optimization by allowing
loading and selection of data from SDDS files into the RPN variables that can be used in
optimization expressions.
- The optimization_setup command now allows specifying that the random number generator
shall be reset to the user-specified seed at the start of every function evaluation. In addition, initial
values of variable and covariable parameters are now available in RPN variables for use in expressions.
- The load_parameters commands now limits the number of warnings about missing parameters
to 100, after which warnings are suppressed.
- The momentum_aperture command now supports fiducialization of the beamline momentum profile
before determining the momentum aperture. This is useful when there is acceleration or energy loss
due to radiation.
Robert Soliday
2007-04-02
