Next: Specialized Tools for Use
Up: Namelist Command Dictionary
Previous: tune_shift_with_amplitude
- type: setup command.
- function: define an index and/or tie a parameter of an element to it.
&vary_element
long index_number = 0;
long index_limit = 0;
STRING name = NULL;
STRING item = NULL;
double initial = 0;
double final = 0;
long differential = 0;
long multiplicative = 0;
long geometric = 0;
STRING enumeration_file = NULL;
STRING enumeration_column = NULL;
&end
index_number -- A non-negative integer giving the number of the index.
index_limit -- A positive integer giving the number of values the index will take.
Must be given if this index_number has not been listed in a previous vary_element
command, unless enumeration_file is given.
name -- The name of an element.
item -- The parameter of the element to vary.
initial, final -- The initial and final values of the parameter.
enumeration_file -- Name of an SDDS file giving values for the item.
enumeration_column -- Column of the SDDS file giving the values.
differential -- If nonzero, the initial and final values are taken as
offsets from the predefined value of the parameter.
multiplicative -- If nonzero, the initial and final values are taken as
multipliers to be applied to the predefined value of the parameter in order to obtain
the actual initial and final values.
geometric -- If nonzero, then variation is geometric rather than
arithmetic.
Robert Soliday
2007-04-02
