Parameter Name | Units | Type | Default | Description |
XMAX | ![]() |
double | 0.0 | size of alpha |
XS1 | ![]() |
double | 0.0 | inner scraper position relative to XMAX |
XS2 | ![]() |
double | 0.0 | outer scraper position relative to XMAX |
DP1 | double | -1 | inner scraper fractional momentum deviation | |
DP2 | double | 1 | outer scraper fractional momentum deviation | |
XPUCK | ![]() |
double | -1 | position of scraper puck |
WIDTHPUCK | ![]() |
double | 0.0 | size of scraper puck |
DX | ![]() |
double | 0.0 | misalignment |
DY | ![]() |
DZ | ![]() |
TILT | double | 0.0 | rotation about incoming longitudinal axis | |
PART | long | 0 |
0=full, 1=first half, 2=second half | |
ORDER | long | 0 |
matrix order [1,3] |
This element provides a matrix-based implementation of an alpha magnet [5].
Matrices up to third order are available [4].
The parameter XMAX determines the size of the alpha, which is related
to the gradient in the magnet and the central momentum
by
(1) |
Because an alpha magnet has large dispersion at the midplane, it is often used
for momentum filtration in addition to bunch compression. The dispersion at the
center is given by the simple relation
(2) |
To split an alpha magnet, one uses the PART parameter. E.g.,
! First half, with momentum filter between -5% and +2.5% AL1: ALPH,XMAX=0.11,PART=1,DP1=-0.05,DP2=0.025 ! Second half AL2: ALPH,XMAX=0.11,PART=2 AL: LINE=(AL1,AL2)
As just illustrated, the parameters DP1 and DP2 may be used to filter the momentum by providing fractional momentum deviation limits. These are implemented in a physical fashion by computing the corresopnding horizontal position deviations and imposing these as limits on the particle coordinates. One may also do this directly using the XS1 and XS2 parameters, which specify maximum acceptable deviations from the nominal horizontal position. XS1 is the allowed deviation on the low-energy side while XS2 is the allowed deviation on the high-energy side.
