Parameter Name | Units | Type | Default | Description |
FILENAME | STRING | filename for histogram output | ||
INTERVAL | long | 1 | interval in passes between output | |
START_PASS | long | 0 |
starting pass for output | |
BINS | long | 50 | number of bins | |
FIXED_BIN_SIZE | long | 0 |
if nonzero, bin size is fixed after the first histogram is made | |
X_DATA | long | 1 | histogram x and x'? | |
Y_DATA | long | 1 | histogram y and y'? | |
LONGIT_DATA | long | 1 | histogram t and p? | |
BIN_SIZE_FACTOR | double | 1 | multiply computed bin size by this factor before histogramming | |
NORMALIZE | long | 1 | normalize histogram with bin size and number of particles? | |
DISABLE | long | 0 |
If nonzero, no output will be generated. |
