| Parameter Name | Units | Type | Default | Description |
| L | double | 0.0 | Length (used for position and time-of-flight computation) | |
| NUX | double | 0.0 | Horizontal tune | |
| NUY | double | 0.0 | Vertical tune | |
| NUX1M | double | 0.0 | First chromatic derivative of the horizontal tune | |
| NUY1M | double | 0.0 | First chromatic derivative of the vertical tune | |
| NUX2M | double | 0.0 | Second chromatic derivative of the horizontal tune | |
| NUY2M | double | 0.0 | Second chromatic derivative of the vertical tune | |
| NUX3M | double | 0.0 | Third chromatic derivative of the horizontal tune | |
| NUY3M | double | 0.0 | Third chromatic derivative of the vertical tune | |
| NUX1AX | double | 0.0 | First amplitude derivative of the horizontal tune wrt Ax | |
| NUY1AX | double | 0.0 | First amplitude derivative of the vertical tune wrt Ax | |
| NUX1AY | double | 0.0 | First amplitude derivative of the horizontal tune wrt Ay | |
| NUY1AY | double | 0.0 | First amplitude derivative of the vertical tune wrt Ay | |
| BETAX | double | 0.0 | On-momentum horizontal beta function | |
| BETAY | double | 0.0 | On-momentum vertical beta function | |
| BETAX1M | double | 0.0 | First chromatic derivative of horizontal beta function | |
| BETAY1M | double | 0.0 | First chromatic derivative of vertical beta function | |
| ALPHAX | double | 0.0 | On-momentum horizontal alpha function |
An Individualized Linear Matrix for each particle for fast symplectic tracking with chromatic and amplitude-dependent effects
| ALPHAY | double | 0.0 | On-momentum vertical alpha function | |
| ALPHAX1M | double | 0.0 | First chromatic derivative of horizontal alpha function | |
| ALPHAY1M | double | 0.0 | First chromatic derivative of vertical alpha function | |
| ETAX | double | 0.0 | On-momentum horizontal eta function | |
| ETAPX | double | 0.0 | On-momentum horizontal eta' function | |
| ETAY | double | 0.0 | On-momentum vertical eta function | |
| ETAPY | double | 0.0 | On-momentum vertical eta' function | |
| ETAX1 | double | 0.0 | First chromatic derivative of horizontal eta function | |
| ETAPX1 | double | 0.0 | First chromatic derivative of horizontal eta' function | |
| ETAY1 | double | 0.0 | First chromatic derivative of vertical eta function | |
| ETAPY1 | double | 0.0 | First chromatic derivative of vertical eta' function | |
| ALPHAC | double | 0.0 | First-order momentum compaction factor | |
| ALPHAC2 | double | 0.0 | Second-order momentum compaction factor |
This element allows fast, symplectic tracking of transport through a
periodic cell with chromatic and amplitude-dependent tunes, beta
functions, and dispersion. This is done by computing a linear matrix
for every particle. The linear matrix is composed from Twiss
parameters, tunes, dispersion, etc., supplied by the user. The user
can also supply selected chromatic and amplitude derivatives of these
quantities, which are used to compute the individual particle's beta
functions, tune, dispersion, etc., which in turn allows computing the
individual particle's linear matrix.
Using this element is very similar to using linear chromatic matrix
tracking via the setup_linear_chromatic_tracking command.
The advantage is that using ILMATRIX, one can split a ring into segments
and place, for example, impedance elements between the segments.
This element was inspired by requests from Y. Chae (APS).
