next up previous
Next: MARK Up: Element Dictionary Previous: MALIGN
MAPSOLENOID
A numerically-integrated solenoid specified as a map of (Bz, Br) vs (z, r).
Parallel capable? : yes
Parameter Name Units Type Default Description
L $M$ double 0.0 length
DX $M$ double 0.0 misalignment
DY $M$ double 0.0 misalignment
ETILT $RAD$ double 0.0 misalignment
EYAW $RAD$ double 0.0 misalignment
EPITCH $RAD$ double 0.0 misalignment
N_STEPS   long 100 number of steps (for nonadaptive integration)
INPUTFILE   STRING NULL SDDS file containing (Br, Bz) vs (r, z). Each page should have values for a fixed r.
RCOLUMN   STRING NULL column containing r values
ZCOLUMN   STRING NULL column containing z values
BRCOLUMN   STRING NULL column containing Br values
BZCOLUMN   STRING NULL column containing Bz values
FACTOR   double 0.0001 factor by which to multiply fields in file
BXUNIFORM   double 0.0 uniform horizontal field to superimpose on solenoid field
BYUNIFORM   double 0.0 uniform vertical field to superimpose on solenoid field
LUNIFORM   double 0.0 length of uniform field superimposed on solenoid field
ACCURACY   double 0.0001 integration accuracy
METHOD   STRING runge-kutta integration method (runge-kutta, bulirsch-stoer, non-adaptive runge-kutta, modified midpoint)
next up previous
Michael Borland 2007-09-07
