| Parameter Name | Units | Type | Default | Description |
| L | double | 0.0 | arc length | |
| ANGLE | double | 0.0 | bending angle | |
| E1 | double | 0.0 | entrance edge angle | |
| E2 | double | 0.0 | exit edge angle | |
| TILT | double | 0.0 | rotation about incoming longitudinal axis | |
| DX | double | 0.0 | misalignment | |
| DY | double | 0.0 | misalignment | |
| DZ | double | 0.0 | misalignment | |
| FINT | double | 0.5 | edge-field integral | |
| HGAP | double | 0.0 | half-gap between poles | |
| FP1 | double | 10 | fringe parameter (tanh model) | |
| FP2 | double | 0.0 | not used | |
| FP3 | double | 0.0 | not used | |
| FP4 | double | 0.0 | not used | |
| FSE | double | 0.0 | fractional strength error | |
| ETILT | double | 0.0 | error rotation about incoming longitudinal axis | |
| ACCURACY | double | 0.0001 | integration accuracy (for nonadaptive integration, used as the step-size) | |
| MODEL | STRING | linear | fringe model (hard-edge, linear, cubic-spline, tanh, quintic, enge1, enge3, enge5) | |
| METHOD | STRING | runge-kutta | integration method (runge-kutta, bulirsch-stoer, modified-midpoint, two-pass modified-midpoint, leap-frog, non-adaptive runge-kutta) | |
| SYNCH_RAD | long | 0 |
include classical synchrotron radiation? | |
| ADJUST_BOUNDARY | long | 1 | adjust fringe boundary position to make symmetric trajectory? (Not done if ADJUST_FIELD is nonzero.) |
A numerically-integrated dipole magnet with various extended-fringe-field models.
| ADJUST_FIELD | long | 0 |
adjust central field strength to make symmetric trajectory? |
