| Parameter Name | Units | Type | Default | Description |
| RA | double | 0.0 | shunt impedance | |
| RS | double | 0.0 | shunt impedance (Ra=2*Rs) | |
| Q | double | 0.0 | cavity Q | |
| FREQ | double | 0.0 | frequency | |
| CHARGE | double | 0.0 | beam charge (or use CHARGE element) | |
| INITIAL_V | double | 0.0 | initial voltage | |
| INITIAL_PHASE | double | 0.0 | initial phase | |
| INITIAL_T | double | 0.0 | time at which INITIAL_V and INITIAL_PHASE held | |
| BETA | double | 0.0 | normalized load impedance | |
| BIN_SIZE | double | 0.0 | bin size for current histogram (use 0 for autosize) | |
| N_BINS | long | 20 | number of bins for current histogram | |
| PRELOAD | long | 0 |
preload cavity with steady-state field | |
| PRELOAD_FACTOR | double | 1 | multiply preloaded field by this value | |
| RIGID_UNTIL_PASS | long | 0 |
don't affect the beam until this pass | |
| DETUNED_UNTIL_PASS | long | 0 |
cavity is completely detuned until this pass | |
| SAMPLE_INTERVAL | long | 1 | passes between output to RECORD file | |
| RECORD | STRING | NULL | output file for cavity fields | |
| SINGLE_PASS | long | 0 |
if nonzero, don't accumulate field from pass to pass | |
| PASS_INTERVAL | long | 1 | interval in passes at which to apply PASS_INTERVAL times the field (may increase speed) | |
| FREQ_WAVEFORM | STRING | NULL |
A simulation of a beam-driven TM monopole mode of an RF cavity.
| Q_WAVEFORM | STRING | NULL | ||
| RAMP_PASSES | long | 0 |
Number of passes over which to linearly ramp up the impedance to full strength. | |
| BINLESS | long | 0 |
If nonzero, use algorithm that doesn't requiring binning. Best for few particles, widely spaced. |
