| Parameter Name |
Units |
Type |
Default |
Description |
| RA |
double |
0.0 |
shunt impedance |
| RS |
double |
0.0 |
shunt impedance (Ra=2*Rs) |
| Q |
double |
0.0 |
cavity Q |
| FREQ |
double |
0.0 |
frequency |
| CHARGE |
double |
0.0 |
beam charge (or use CHARGE element) |
| BETA |
double |
0.0 |
normalized load impedance |
| BIN_SIZE |
double |
0.0 |
bin size for current histogram (use 0 for autosize) |
| N_BINS |
long |
20 |
number of bins for current histogram |
| PLANE |
STRING |
both |
x, y, or both |
| SAMPLE_INTERVAL |
long |
1 |
passes between output to RECORD file |
| PER_PARTICLE_OUTPUT |
long |
0 |
If non-zero, then in BINLESS mode, provides per-particle output of RECORD data. |
| RECORD |
STRING |
NULL |
output file for cavity data |
| SINGLE_PASS |
long |
0 |
if nonzero, don't accumulate field from pass to pass |
| RIGID_UNTIL_PASS |
long |
0 |
don't affect the beam until this pass |
| DX |
double |
0.0 |
misalignment |
| DY |
double |
0.0 |
misalignment |
| XFACTOR |
double |
1 |
factor by which to multiply shunt impedances |
| YFACTOR |
double |
1 |
| RAMP_PASSES |
long |
0 |
Number of passes over which to linearly ramp up the impedance to full strength. |
| BINLESS |
long |
0 |
If nonzero, use algorithm that doesn't requiring binning.  Best for few particles, widely spaced. |
