Example runs and post-processing files are included along with the distribution of elegant. These are drawn from the author's research and all concern various aspects of the Argonne Positron Accumulator Ring (PAR) and its injection and ejection lines (LTP and PTB, respectively).
The examples are intended to demonstrate program capabilities with
minimal work on the user's part.  Each demo is invoked using a command
(a C-shell script) that can both run elegant and post-process
the output.  After running the demo, the output can be viewed again
without rerunning elegant by invoking the command with the word
review added to the command line.  Including the word
hardcopy on the command line results in the graphs being sent
to the default printer, which is assumed to accept Postscript.
The post-processing is typically handled by a lower-level script that is called from the demo script. These lower-level scripts are good models for the creation of customized scripts for user applications.
par10h* -- These files provide a demonstration of Twiss
parameter computation, tracking, element variation, and map analysis.
The lattice is defined with kick elements, which are used for all
tracking.  After computation of the Twiss parameters for the
PAR[6], a series of particles are tracked with different
initial x coordinates.  Finally, the tunes and Twiss parameters are
computed by tracking; they are very close to the analytical values.
The post-processing commands make phase-space plots and plots of FFTs
of the motion, showing that the motion becomes chaotic at the
stability limit.  To execute this demo, type the command
par10h.
par_sympl* -- These files provide a demonstration of the
symplecticity of tracking with elegant kick elements.  A single
large-amplitude particle is tracked for par_sympl.
The post-processing takes quite some time because of the very large
number of points.
par_chrom* -- These files provide a demonstration of
computing chromaticity and other parameters as a function of momentum
offset using map analysis.  The lattice is the same as
par10h.lte, except all of the elements are implemented using
second-order matrices.  Hence, the chromaticity from tracking should
be nearly identical to the analytical results computed by the
twiss_output command, which it is.  To run this demonstration,
enter par_chrom.  The reader may wish to try this demo again
using ksbend, csbend, or nibend elements in place
of the sbend elements, and kquad (ksext) elements
in place of the quad (sext) elements.
par_damp* -- These files provide a demonstration of
damping partition calculation using single turn tracking with
synchrotron radiation.  The expected value of the longitudinal damping
partition for PAR is
par_damp.lte, to invoke a different element for
the dipole magnet.  In particular, definitions for numerically
integrated dipoles with extended fringe-fields are present.  To
execute this demo, type the command par_damp.
par_dynap* -- These files provide a demonstration of
dynamic aperture runs for a series of randomized machines.  Also
exhibited here are orbit, tune, and chromaticity correction.  The
post-processing commands make a plot of the dynamic apertures with the
physical aperture superimposed.  (The orbcorr_plots script can
also be used to plot orbit correction information.) To execute this
demo, type the command par_dynap.  The lattice has been
stripped down so that only a few of the more significant multipoles
are present.  Also, fictitious extra sextupoles have been added to
compensate the lack of second-order edge terms in the bending magnets
(these would result in nonsymplectic tracking if included).  Still,
the running time is many hours.
ejoptk* -- These files provide a demonstration of the
optimization of a multi-turn ejection bump for PAR, using a
time-dependent kicker waveform (formed from two cubic splines).  After
optimization, the lattice is tracked with a realistic beam
distribution to verify good transmission and show the centroid
position vs z over three turns.  To execute this demo, type the
command ejoptk.
ltp_te* -- These files provide a demonstration of
transport line simulation.  The Linac-to-PAR transport line is
simulated with errors and trajectory correction to predict the
transmission losses and the steering error at the exit of the septum.
The trajectory correction uses tracking of a beam distribution, which
is slower than tracking the centroid, but which produces better
results in the presence of the large momentum spread.  The reader may
wish to verify this by turning off this feature and running the
simulation again.  To execute this demo, type the command
ltp_te.  The running time for this demo is quite long.
