&momentum_aperture
STRING output = NULL;
double x_initial = 0;
double y_initial = 0;
double delta_negative_start = -0.10;
double delta_positive_start = 0.10;
long delta_step_size = 0.01;
long oversteps = 1;
long splits = 2;
long steps_back = 4;
double s_start = 0;
double s_end = DBL_MAX;
STRING include_name_pattern = NULL;
long fiducialize = 0;
long verbosity = 0;
&end
output -- The (incomplete) name of a file to which the momentum aperture results will be written.
Recommended value: ``%s.mmap''.
x_initial, y_initial -- The initial x and y coordinate values for tracking. It is essential
that y_initial be nonzero if one wants to see losses due to vertical resonances.
delta_negative_start, delta_positive_start --
Start values of scans in the negative and positive
directions. Scanning begins at these and moves toward 0.
delta_step_size -- Initial size of steps in oversteps -- Number of step sizes to go past the point of first
survival before reversing the direction of scanning.
splits -- Number of times to split the step size in
order to refine the location of the maximum surviving momentum
offsets. When a particle is lost, the algorithm steps back to a momentum offset
where a particle survived, subdivides the step size, and continues searching.
steps_back -- When performing interval splitting, when a particle is
lost, the algorithm steps back to a momentum offset where a particle survived.
This method helps to ensure that the algorithm did not find a stable island.
This is the number of steps to go back.
s_start, s_end -- Limiting s coordinates of the
elements from which tracking will start. The default values will
exclude no elements.
include_name_pattern -- If given, tracking will start
only at the entrance to elements that match the given wildcard
pattern.
fiducialize -- If given, an initially on-energy particle is tracked before
the momentum aperture search begins, in order to fiducialize the reference momentum.
This is useful if there are synchrotron radiation losses or energy gain due to cavities
in the system.
verbosity -- Larger values result in more detailed
printouts as calculations proceed. Mostly for debugging.
The idea for this command is from M. Belgroune et al., ``Refined Tracking Procedure for the SOLEIL Energy Acceptance Calculation,'' Proceedings of PAC 2003, p 896, as implemented for TRACYII. In particular, the energy aperture as a function of position around the ring is determined by tracking. Starting at the beginning of the lattice and working downstream, particles are tracked starting from the exit of each selected element. The betatron coordinates are initially zero (or very small), while the momentum deviation is gradually increased until loss of the particle is observed. This defines the momentum aperture at that location.
In elegant, the algorithm is as follows. For simplicity in wording, we'll assume the momentum deviations are positive values, although the method is applied separately for negative values as well:
