Next: New and Modified Elements
Up: Highlights of What's New
Previous: Bugs Fixes for Commands
- The CWIGGLER element had an error in the ordering of rotation and displacement removal
operations. Simulations that contained both rotational
and displacement errors for the same
CWIGGLER element should be repeated.
- There was an error in an exponent for synchrotron radiation expressions, resulting
in incorrect dependence of the quantum fluctuations on transverse position in a dipole, quadrupole,
or sextupole. Tests with the APS ring showed small effects on results even for orbits with
several percent momentum deviation.
- The correction to the response matrix when there was dispersion at the corrector was being
added with the wrong sign. This would affect response matrix output in the bending plane.
This is a minor effect in large rings but quite significant in small rings.
Reported by Michael Abo-Bakr (BESSY).
- When particles were lost on an
ECOL element with non-zero length, the loss locations
were recorded incorrectly. Reported by Feng Zhou (SLAC).
- The
FTRFMODE element, which allows simulating multiple tranverse rf modes, had an unitialized
variable that would result in incorrect accumulation of voltages over many passes.
- Previously, the transverse space-charge element
SCMULT could be inserted by hand into the
lattice, but it wouldn't actually run. Now, the user is required to provide a insert_sceffects
command to use SCMULT.
- The longitudinal space charge algorithm (
LSCDRIFT and RFCW) would give give
invalid results if the number of bins was odd. This odd choice of bin number is no longer allowed.
Michael Borland
2007-09-07
