&rpn_load
STRING tag = NULL;
STRING filename = NULL;
STRING match_column = NULL;
STRING match_column_value = NULL;
long matching_row_number = -1;
STRING match_parameter = NULL;
STRING match_parameter_value = NULL;
long use_row = -1;
long use_page = -1;
&end
This command is used to facilitate multi-stage optimization runs by allowing convenient loading of data from SDDS files into RPN variables. For example, one may match the final Twiss parameters of a lattice to the parameters stored in an SDDS file from a different run.
tag -- A string that will be pre-pended to the names of all the numerical columns
in the file in order to create RPN variable names. E.g., if the input file was from the
twiss_output command and tag = tw1 was given, then RPN variables
tw1.betax, tw1.alphax, etc. would be used.
match_column -- The name of a string column to use in selecting the row from
which data will be taken.
match_column_value -- The value that the column named by match_column must
have to be selected from the file. By default, the last row with a matching value is used.
matching_row_number -- If a nonnegative value is given, then the matching_row_numbermatch_column is not
given.
match_parameter -- The name of a string parameter to use in selecting the page
from which data will be taken.
match_parameter_value -- The value that the parameter named by match_parameter must
have to be selected from the file. By default, the last page with a matching value is used.
use_row -- If nonnegative, specifies the row number to use, starting at 0 for the first row.
Ignored if match_column is given.
use_page -- If nonnegative, specifies the page number to use, starting at 1 for the first page.
Takes precedence over \match_parameter if both are given.
