Next: slice_analysis
Up: Namelist Command Dictionary
Previous: sdds_beam
- type: setup command.
- function: set up names for semaphore files, which are used to mark the
start and end of program execution.
&semaphores
STRING started = ``%s.started'';
STRING done = ``%s.done'';
&end
- started -- Gives the (incomplete) filename of a file to create when a valid
run_setup command is given.
- done -- Gives the (incomplete) filename of a file to create when the program
exits without error. If the file exists, it is deleted when a valid run_setup
command is given.
Michael Borland
2007-09-07
