Next: tune_shift_with_amplitude
Up: Namelist Command Dictionary
Previous: twiss_output
- type: action command.
- function: track particles.
&track
long center_on_orbit = 0;
long center_momentum_also = 1;
long offset_by_orbit = 0;
long offset_momentum_also = 1;
long soft_failure = 1;
long use_linear_chromatic_matrix = 0;
long longitudinal_ring_only = 0;
long stop_tracking_particle_limit = -1;
&end
center_on_orbit -- A flag indicating whether to center
the beam transverse coordinates on the closed orbit before tracking.
center_momentum_also -- A flag indicating whether to
center the momentum coordinate also.
offset_by_orbit -- A flag indicating whether to offset
the transverse beam coordinates by the closed orbit before tracking.
Similar to center_on_orbit, but the initial centroids of the
beam are preserved. The beam is simply displaced by the closed orbit
rather than being centered on it.
offset_momentum_also -- A flag indicating whether to also
offset the beam momentum to the momentum of the closed orbit. If the
start_from_centroid or start_from_dp_centroid parameters are
used on the closed_orbit command, this flag should be set to
0; otherwise, one will offset the beam central momentum by its own value.
soft_failure -- If there is an error during tracking (e.g.,
a failure of orbit correction), continue to produce file output. This
creates essentially empty slots in the files corresponding to the failed
steps.
use_linear_chromatic_matrix -- For each particle, a first-order
matrix is computed for the particular momentum offset
of the particle using the linear chromaticity and linear dependence of
the beta functions on momentum.
longitudinal_ring_only -- Tracks longitudinal coordinates only
for a ring.
stop_tracking_particle_limit -- If a non-negative is given, then
elegant will stop tracking when the number of particles falls below the
given value. It will be as if all the particles were lost.
Michael Borland
2007-09-07
