Next: FRFMODE
Up: Element Dictionary
Previous: FLOOR
Multipole kick element with coefficient input from an SDDS file.
Parallel capable? : yes
| Parameter Name |
Units |
Type |
Default |
Description |
| L |
double |
0.0 |
length |
| TILT |
double |
0.0 |
rotation about longitudinal axis |
| DX |
double |
0.0 |
misalignment |
| DY |
double |
0.0 |
misalignment |
| DZ |
double |
0.0 |
misalignment |
| FSE |
double |
0.0 |
fractional strength error |
| N_KICKS |
long |
1 |
number of kicks |
| SYNCH_RAD |
long |
0 |
include classical synchrotron radiation? |
| FILENAME |
STRING |
NULL |
name of file containing multipole data |
| SQRT_ORDER |
long |
0 |
Order of expansion of square-root in Hamiltonian. 0 means no expansion. |
This element simulates a multipole element using a 4th-order sympletic
integration.
Specification of the multipole strength is through an SDDS file.
The file is expected to contain a single page of
data with the following elements:
- An integer column named order giving the order of the multipole.
The order is defined as
, so a quadrupole has order 1, a
sextupole has order 2, and so on.
- A floating point column named KnL giving the integrated strength of
the multipole,
, where
is the order. The units are
- A floating point column named JnL giving the integrated strength of
the skew multipole,
, where
The MULT element is also available, which allows the same
functionality without an external file.
Next: FRFMODE
Previous: FLOOR
Michael Borland
2007-09-07
