Next: Input Beam File
Up: Input Files
Previous: Input Files
Cross-section Data File
This file is required by the EGS4 subroutines, and contains most of
the physics of the simulation. The cross-section data is created by
program PEGS4, the EGS4 preprocessor. PEGS4 has to be run once for
each material type in an EGS4 simulation. The material can be an
element, compound or mixture. The resulting data file is an ascii
text file that an EGS4 subroutine will parse and store as
cross-section data. One normally pre-calculates a number of materials
and combine the individual cross-section files into a larger file. A
file with several material types that have been used at APS is provided in
the distribution.
Program shower looks for this file in the environment variable EGS4_CROSSSECTION. If EGS4_CROSSSECTION is undefined, the
program looks for the file fort.12 in the current
directory. (The name fort.12 comes from the conventional
implementation of EGS4.)
Robert Soliday
2003-10-17
