&define_antenna
start = 0.01, end = 0.02, position = 0.03,
direction = "z",
current = 1,
frequency = 2856e6,
waveform = "spline.wf"
&end
This defines a current source in the longitudinal direction extending from
z of 1cm to 2cm at a radius of 3cm. The amplitude of the current is
1A with a frequency of 2856MHz, modulated by the envelope in SDDS file
spline.wf.
&define_antenna
double start = 0;
double end = 0;
double position = 0;
STRING direction = "z";
double current = 0;
double frequency = 0;
double phase = 0;
STRING waveform = NULL;
double time_offset = 0;
&end
