Adds on-axis field data to the simulation. The user must provide an
SDDS file giving
. This data is used to compute
, and
using an off-axis
expansion in
and assuming
and
Any number of add_on_axis_fields commands may be given.
&add_on_axis_fields filename = fieldProfile.sdds, z_name = z, Ez_name = Ez, Ez_peak = 30e6, phase = 180, expansion_order = 2 fields_used = fieldUsed.sdds, &end
This command loads on-axis field data from columns z and
Ez in fieldProfile.sdds, and scales it so that the peak
field is 30 MV/m. The phase,
, is set to 180 degrees. Because
spiffe simulates electrons, if
is positive, the phase
factor must be negative to provide acceleration. I.e.,
is the accelerating phase.
#namelist add_on_axis_fields
STRING filename = NULL;
STRING z_name = NULL;
STRING Ez_name = NULL;
double Ez_peak = 0;
double frequency = 0;
double z_offset = 0;
long expansion_order = 3;
STRING fields_used = NULL;
#end
