4 Library Reference
#include “libruncontrol.h”
runControlInit
int runControlInit(char *pv, char *desc, float timeout, char *handle, RUNCONTROL_INFO *rcInfo, double pendIOtime);
Grab control of the specified EPICS runcontrol record, and load it with various application information, such as process-id, hostname, username, and start time. A specific record may be given via the pv argument, or NULL may be given and the next free runcontrol record will be found for you.
Returns:
runControlPing
int runControlPing(char *handle, RUNCONTROL_INFO *rcInfo);
Notifies runcontrol record that you application is still alive. Also provides a means for runcontrol record to suspend you, or request that you abort. The return codes from this call must be checked and acted on properly.
Returns:
runControlExit
int runControlExit(char *handle, RUNCONTROL_INFO *rcInfo);
Release control of the runcontrol record.
Returns:
runControlLogMessage
int runControlLogMessage(char *handle, char *message, short severity, RUNCONTROL_INFO *rcInfo);
Log a message and new alarm severity to the runcontrol record. The runcontrol record will enter given alarm state.
Returns:
