sddscollect reorganizes tabular data from the input file
to bring data from several groups of similarly named columns together into
a single column per group. In doing so, it creates one page of output
for every row on the input file. It also creates parameters to
hold data from columns that are not included in any group.
x, y, and
Rootname. The latter column contains the original column
names less the ``x'' (or ``y'') suffix.
Do statistics on PAR BPM x and y readbacks, then collect the statistics into columns, one column for each type of statistic:
sddscollect would abort and give
an error message.
This option may be given any number of times. However, all collections must produce the same number of matches. Further the set of name remainders (i.e., the original column name less the prefix or suffix, or following editing) must be the same for each collection.
