outputFile contains a column f for the frequency, along with one or more columns for each independent variable. By default, outputFile has one column named FFTindepName containing the magnitude of the FFT for each independent variable. If -fullOutput is specified, outputFile contains additional columns for, respectively, the phase (or argument), real part, and imaginary part of the FFT: ArgindepName, RealindepName, and ImagindepName. If power-spectral-density output is requested, then a column PSDindepName is also created.
outputFile also contains two parameters, fftFrequencies and fftFrequencySpacing, giving the number of frequencies and the frequency spacing, respectively.
pipe[=input][,output] -- The standard SDDS Toolkit pipe option.
-padWithZeros -- Specifies that the independent data should be padded with zeros to
make the number of points equal to the nearest power of two. In some cases, this will result in
significantly greater speed.
-truncate -- Specifies that the data should be truncated so that the number of points is
the largest product of primes from 2 to 19 not greater than the original number of points.
In some cases, this will result in significantly greater speed.
normalize -- Specifies that FFT's will be normalized to give a maximum magnitude of 1.
suppressAverage -- Specifies that the average value of the data will be subtracted from
every point prior to taking the FFT. This may improve accuracy and visibility of small components.
fullOutput -- Specifies that in addition to the magnitude, the phase, real part, and imaginary
part of each FFT will be included in the output.
psdOutput -- Specifies that in in addition to ordinary FFT data, the power-spectral-densities
will also be included in the output. The units of the PSD are of the form
