- description:
sddsnaff is an implementation of Laskar's Numerical Analysis of Fundamental
Frequencies (NAFF) algorithm. This algorithm provides a way of determining the frequency
components of a signal that is more accurate than Fast Fourier Transforms (FFT).
FFTs are used as part of the analysis, so if an FFT is sufficient for an application,
sddsfft should be used as it will be much faster.
The algorithm starts by removing the average value of the signal and
applying a Hanning window. Next, the signal is FFT'd and the
frequency at which the maximum FFT amplitude occurs is found. This is
taken as the starting frequency for a numerical optimization of the
``overlap'' between the signal and
, which allows
determining
to resolution greater than the frequency spacing
of the FFT. Once
is determined, the overlap is subtracted
from the original signal and the process is repeated, if desired.
- examples:
Find the first fundamental frequency for each of the BPM signals in par.bpm.
sddsnaff par.bpm par.naff -column=Time,'P?P?x' -terminateSearch=frequencies=1
- synopsis:
sddsnaff [inputfile] [outputfile]
[-pipe=[input][,output]]
[-columns=indep-variable[,depen-quantity[,...]]]
[-exclude=depen-quantity[,...]]
[-terminateSearch=changeLimit=fraction[,maxFrequencies=number] | frequencies=number]
[-iterateFrequency=[cycleLimit=number][,accuracyLimit=fraction]]
[-truncate] [-noWarnings]
- files:
inputFile contains the data to be NAFF'd. One column from this
file must be chosen as the independent variable. If inputFile
contains multiple pages, each is treated separately and is delivered
to a separate page of outputFile.
outputFile contains two columns for each selected column in inputFile. These columns have names like origColumnFrequency and origColumnAmplitude, giving the frequency
and amplitude for origColumn.
- switches:
pipe[=input][,output] -- The standard SDDS Toolkit pipe option.
- -columns=indepVariable[,depenQuantityList] -- Specifies the name of the
independent variable column. Optionally, specifies a list of comma-separated, optionally
wildcard-containing names of dependent quantities to be NAFF'd as a function of the
By default, all numerical columns except the independent column are NAFF'd.
- -exclude=depenQuantity,... -- Specifies optionally wildcarded names of columns
to exclude from analysis.
- -terminateSearch={changeLimit=fraction[maxFrequencies=number] |
frequencies=number} -- Specifies when to stop searching for frequency
components. If changeLimit is given, then the program stops when the RMS change
in the signal is less than the specified fraction of the original RMS value of
the signal. The maximum number of frequencies that will be returned in this mode
is specified with maxFrequencies (default is 4). If frequencies is given,
then the program finds the given number of frequencies, if possible.
By default, the program finds one frequency for each signal.
- -iterateFrequency=[cycleLimit=number][,accuracyLimit=fraction] --
This option controls the optimization procedure that searches for the best frequency.
By default, the procedure executes 100 passes and attempts to determine the frequency
to a precision of 0.00001 of the Nyquist frequency.
cycleLimit is used to change the number of passes, while accuracyLimit is used
to specify the desired precision.
-truncate -- Specifies that the data should be truncated so that the number of points is
the largest product of primes from 2 to 19 not greater than the original number of points.
In some cases, this will result in significantly greater speed, by making the FFTs faster.
-noWarnings -- Suppresses warning messages.
- see also:
- author: M. Borland, ANL/APS.
