Next: randomizeHOMFrequencies
Up: List of Namelist Commands
Previous: bunchPatternFromFile
- type: Setup command.
- function: The command defines the randomization parameters for
the bunch pattern. The randomization is performed on the ideal bunch
pattern before each growth rate calculation. If a sweep of frequency
is requested (sweepFrequency), then a new random bunch pattern
is generated for each HOM frequency value. If a HOM-frequency Monte
Carlo simulation is requested (randomizeHOMFrequencies), then a
new random bunch pattern is generated for each HOM frequency
sample. Thus there are two random components in the resulting growth
rate distribution: HOM frequency and bunch population.
&randomizeBunchCurrent struct
long seed = -987654323;
long uniform = 1;
double absoluteSpreadMA = 0;
double relativeSpread = 0;
&end.
- seed -- A large negative number for the random number generator. This will use an independent generator from the HOM frequency.
- uniform -- Flag for uniform distribution. Presently only uniform distribution is available.
- absoluteSpreadMA -- Spread in bunch distribution in units of mA. This is useful in top-up mode injection where the total current is constant but
individual bunches have spread equal to the charge per injection bunch. For example if a bunch pattern has 4 mA per bunch and the spread is 1 mA, then some bunches may have current as low as 3.5 mA and others as high as 4.5 mA.
- relativeSpread -- Spread in bunch distribution in fraction.
subsectionsweepFrequency
- function: Sets up a sweep of the resonator frequency value of a
selected HOM. The setup takes effect only when an action command is
executed.
&sweepHOMFrequency
long resonatorNumber = 0
double frequencyRange = 0.0
long points = 100
STRING filename = NULL
&end
- resonatorNumber -- HOM resonator number to be swept in
frequency. The numbering starts at 0, and proceed in the order that
the resonators were read in the HOM definition file or files.
- frequencyRange -- Sweep range in Hz. The range starts
at the unperturbed HOM resonator frequency minus frequencyRangeHz and ends at the unperturbed HOM resonator frequency
plus frequencyRangeHz. If frequencyRangeHz is set to 0 or
not specified, then frequencyRangeHz=
where
is the
revolution frequency.
- points -- Number of points in the sweep.
- filename -- SDDS file in which the results are
written. The columns are the swept HOM frequency, the maximum growth
rate, and the frequency shift of the fastest growing CBM. Recommended
naming conventions: <something>.CBMFreq
Randy Flood
2006-11-06
