Next: doLongitudinalMotion
Up: List of Namelist Commands
Previous: randomizeBunchCurrent
- type: Setup command
- function: Sets up a Monte Carlo simulation of randomized HOM
frequencies for all HOMs. The setup takes effect only when an action
command is executed.
&randomHOMFrequencies
double spread = 0.0
long seed = -987654321
long uniform = 1
long samples = 100
STRING CBMFrequencyFilename = NULL
STRING HOMFrequencyFilename = NULL
&end
- spread -- The range of the random component of the
frequency values is -spread to spread in Hz. If spread is set
to zero or left undefined, then spread =
where
is the
revolution frequency.
- seed -- A large negative number for the random number generator. This will use an independent generator from the bunch population randomizer.
- uniform -- If flag is set to 1, then a uniform
distribution for the random component of the HOM frequencies is used.
Since no other random distribution type is avaiblable in this present
version of clinchor using other values of uniform makes no
difference.
- samples -- Gives the number of times a following action
command ( doLongitudinalMotion or doTransverseMotion)is
executed with a different sampling of random HOM frequencies for each
calculation.
- CBMFrequencyFilename -- File containing the growth rate value of the
fastest growing mode in each Monte Carlo sample. This file can then
be histogrammed with the SDDS toolkit program sddshist. Recommended
naming conventions: <something>.CBMFreq
- HOMFrequencyFilename -- SDDS file containing the
randomized HOM frequencies used by each Monte Carlo sample. Type ``sddsquery <filename>'' for the full description of the file. This
file may grow to be very large, so be careful with this option. This
variable is optional. Recommended naming conventions: <something>.HOMFreq
Randy Flood
2006-11-06
