If the optional command sweepFrequency is in effect, the SDDS file specified by the filename variable in that namelist command is opened at this point.
If the optional command randomizeHOMFrequencies is in effect, the SDDS files specified by the filename and frequencyListFilename variables in that namelist command are opened at this point.
&doLongitudinalMotion long normalModes = 1 long doLaplace = 0 STRING eigenvectorFilename = NULL; STRING CBMFrequencyFilename = NULL &end
