&link_elements
    STRING target = NULL;
    STRING exclude = NULL;
    STRING item = NULL;
    STRING source = NULL;
    STRING source_position = "before";
    STRING mode = "dynamic";
    STRING equation = NULL;
&end
target -- The name of the elements to be modified by the link.  May contain
 wild-cards.
exclude -- Wildcard sequence to match to element names.  If a match is found,
 the element is excluded from the link.
item -- The parameter that will be modified.
source -- The name of the elements to be linked to.
source_position -- May be one of ``before'', ``after'',
``adjacent'', ``nearest'', or ``same-occurrence''.
mode -- May be either ``dynamic'' or ``static''.  A dynamic link
is asserted whenever the source is changed (during correction, for example).
A static link is asserted only when an error or variation is imparted to
the source, and at the end of correction.
equation -- An rpn equation for the new item value in
terms of the item values for the source.  The prior value of the item is
on the top of the stack. To refer to the source
parameter values, use the name of the parameters. These names must appear
in capital letters.
