Next: matrix_output
Up: Namelist Command Dictionary
Previous: link_elements
- type: setup command.
- function: load parameters for elements from an SDDS file.
&load_parameters
STRING filename = NULL;
long change_defined_values = 0;
long clear_settings = 0;
long allow_missing_elements = 0;
long verbose = 0;
&end
filename -- Name of SDDS file from which to take data. The file
must contain some of the following columns:
- ElementName -- Required string column. The name of the element to change.
- ElementParameter -- Required string column. The name of the parameter of the element to change.
- ParameterValue -- Optional double column. If given, gives value of the parameter named
in ElementParameter for element named in ElementName.
- ParameterValueString -- Optional string column. If ParameterValue is not present, then
this column must be present. The string data will be scanned, if necessary,
to obtain a value for the parameter.
- ParameterMode -- Optional string column. If given, for each row the value must be
one of ``absolute'', ``differential'', ``ignore'', or ``fractional''.
Unless change_defined_values is set, successive pages of the file are used for
successive steps of the simulation. Several elegant commands generate output that
may be used (on a subsequent run) with load_parameters; among these are
the tune and chromaticity correction commands and the run_setup command (parameters output).
change_defined_values -- Changes the defined values of the parameters.
This means that when the lattice is saved (using save_lattice), the parameters will
have the altered values. Also, if you want to alter the values for all steps of the
simulation, you must set this flag.
clear_settings -- If set, clear all settings and files being used for loading parameters.
allow_missing_elements -- If set, allow elements in the file that are not in
the lattice. In this case, the nonapplicable data is simply ignored.
verbose -- If set, provide informational printouts about changes to parameters.
Next: matrix_output
Michael Borland
2001-06-08
