&vary_element long index_number = 0; long index_limit = 0; STRING name = NULL; STRING item = NULL; double initial = 0; double final = 0; long differential = 0; long multiplicative = 0; long geometric = 0; STRING enumeration_file = NULL; STRING enumeration_column = NULL; &end
index_number
-- A non-negative integer giving the number of the index.
index_limit
-- A positive integer giving the number of values the index will take.
Must be given if this index_number
has not been listed in a previous vary_element
command, unless enumeration_file
is given.
name
-- The name of an element.
item
-- The parameter of the element to vary.
initial
, final
-- The initial and final values of the parameter.
enumeration_file
-- Name of an SDDS file giving values for the item.
enumeration_column
-- Column of the SDDS file giving the values.
differential
-- If nonzero, the initial and final values are taken as
offsets from the predefined value of the parameter.
multiplicative
multipliers to be applied to the predefined value of the parameter in order to obtain
the actual initial and final values.
geometric
-- If nonzero, then variation is geometric rather than
arithmetic.
