| Parameter Name | Units | Type | Default | Description |
| L | double | 0.0 | arc length | |
| ANGLE | double | 0.0 | bend angle | |
| K1 | double | 0.0 | geometric quadrupole strength | |
| K2 | double | 0.0 | geometric sextupole strength | |
| K3 | double | 0.0 | geometric octupole strength | |
| K4 | double | 0.0 | geometric decapole strength | |
| E1 | double | 0.0 | entrance edge angle | |
| E2 | double | 0.0 | exit edge angle | |
| TILT | double | 0.0 | rotation about incoming longitudinal axis | |
| H1 | double | 0.0 | entrance pole-face curvature | |
| H2 | double | 0.0 | exit pole-face curvature | |
| HGAP | double | 0.0 | half-gap between poles | |
| FINT | double | 0.5 | edge-field integral | |
| DX | double | 0.0 | misalignment | |
| DY | double | 0.0 | misalignment | |
| DZ | double | 0.0 | misalignment | |
| FSE | double | 0.0 | fractional strength error | |
| ETILT | double | 0.0 | error rotation about incoming longitudinal axis | |
| N_KICKS | long | 4 | number of kicks | |
| NONLINEAR | long | 1 | include nonlinear field components? | |
| SYNCH_RAD | long | 0 |
include classical synchrotron radiation? | |
| EDGE1_EFFECTS | long | 1 | include entrace edge effects? | |
| EDGE2_EFFECTS | long | 1 | include exit edge effects? | |
| INTEGRATION_ORDER | long | 2 | integration order (2 or 4) | |
| BINS | long | 0 |
number of bins for CSR wake | |
| BIN_RANGE_FACTOR | double | 1.2 | Factor by which to increase the range of histogram compared to total bunch length. Large value eliminates binning problems in CSRDRIFTs. |
Like CSBEND, but incorporates a simulation of Coherent Synchrotron radiation.
| SG_HALFWIDTH | long | 0 |
Savitzky-Golay filter half-width for smoothing current histogram | |
| SG_ORDER | long | 1 | Savitzky-Golay filter order for smoothing current histogram | |
| SGDERIV_HALFWIDTH | long | 0 |
Savitzky-Golay filter half-width for taking derivative of current histogram | |
| SGDERIV_ORDER | long | 1 | Savitzky-Golay filter order for taking derivative of current histogram | |
| OUTPUT_FILE | STRING | NULL | output file for CSR wakes | |
| OUTPUT_INTERVAL | long | 1 | interval (in kicks) of output to OUTPUT_FILE | |
| OUTPUT_LAST_WAKE_ONLY | long | 0 |
output final wake only? | |
| STEADY_STATE | long | 0 |
use steady-state wake equations? | |
| USE_BN | long | 0 |
use B |
| B1 | double | 0.0 | K1 = B1*rho, where rho is bend radius | |
| B2 | double | 0.0 | K2 = B2*rho | |
| B3 | double | 0.0 | K3 = B3*rho | |
| B4 | double | 0.0 | K4 = B4*rho | |
| ISR | long | 0 |
include incoherent synchrotron radiation (scattering)? | |
| CSR | long | 1 | enable CSR computations? |
