| Parameter Name |
Units |
Type |
Default |
Description |
| L |
double |
0.0 |
length |
| ATTENUATION_LENGTH |
double |
0.0 |
exponential attenuation length for wake |
| DZ |
double |
0.0 |
interval between kicks |
| N_KICKS |
long |
1 |
number of kicks (if DZ is zero) |
| SPREAD |
long |
0 |
use spreading function? |
| USE_OVERTAKING_LENGTH |
long |
0 |
use overtaking length for ATTENUATION_LENGTH? |
| USE_SALDIN54 |
long |
0 |
Use Saldin et al eq. 54 (NIM A 398 (1997) 373-394 for decay vs z? |
| SALDIN54POINTS |
long |
20 |
Number of values of position inside bunch to average for Saldin eq 54. |
| CSR |
long |
1 |
do CSR calcuations |
| SPREAD_MODE |
STRING |
full |
full, simple, or radiation-only |
| WAVELENGTH_MODE |
STRING |
sigmaz |
sigmaz or peak-to-peak |
| BUNCHLENGTH_MODE |
STRING |
68-percentile |
rms, 68-percentile, or 90-percentile |
| SALDIN54_OUTPUT |
STRING |
NULL |
Filename for output of CSR intensity vs. z as computed using Saldin eq 54. |
| OL_MULTIPLIER |
double |
1 |
factor by which to multiply the overtaking length to get the attenuation length |
